Acer Flow Silent Wireless Mouse | Bluetooth & 2.4GHz Dual Mode | 3-Level 1600 DPI | 500mAh Rechargeable Battery | Up to 1 Month Usage | Type-C Charging | 10m Range | Ambidextrous Design | Ivory
ZC.A01SI.68Z
ZC.A01SI.68Z
  • BLUETOOTH + 2.4GHz DUAL-MODE WIRELESS: Enjoy flexible wireless connectivity with both Bluetooth and 2.4GHz modes. Simply plug the included USB receiver into your device for automatic 2.4GHz connection or pair the mouse through Bluetooth, then conveniently switch between the two modes using the dedicated mode key.
  • 3-LEVEL ADJUSTABLE 800/1200/1600 DPI: Switch between 800, 1200 and 1600 DPI sensitivity levels using the dedicated DPI adjustment button to suit different tasks. Choose greater control for everyday office work or increase cursor sensitivity when navigating larger displays and documents. The keys are rated for up to 3 million operations.
  • SILENT CLICK & COMFORTABLE DESIGN: Designed for quieter everyday working with 4D silent left and right keys and a comfortable touch feel. The symmetrical design is suitable for both left- and right-handed users, making Acer Flow a practical choice for work, study and everyday computing.
  • 500mAh RECHARGEABLE BATTERY – UP TO 1 MONTH USAGE: Forget the hassle of frequently replacing disposable batteries. Acer Flow features an integrated 500mAh rechargeable battery providing approximately 1 month of usage, with a specified charging time of approximately 3 hours for convenient everyday productivity.
  • TYPE-C CHARGING & UP TO 10M WIRELESS RANGE: Stay connected comfortably across your workspace with a wireless working distance of up to 10 metres. The mouse supports convenient Type-C charging and comes with a Type-C charging cable. Its compact 100 × 60 × 38mm body weighs just 61g, making it convenient for office, home and travel use.
  • MRP: ₹ 999.00 (Inclusive of all taxes) per unit
  • Country of Origin: China
Regular Price ₹999.00 Special Price ₹399.00
Only 2 left
Check Estimated Delivery Date
Details
HeaderHeader
Frame-01Frame-01
Frame-02Frame-02
Frame-03Frame-03
Frame-04Frame-04
Frame-05Frame-05
Frame-06Frame-06
▶ Technical Information
Compatibility
Compatible with PC, Laptop, MacBook and iPad
▶ Network & Communication
Connectivity Speed
2.4 GHz Wireless & Bluetooth
▶ Battery
Number of Cells
1 Lithium Ion batteries required
Battery Chemistry
Battery Capacity
Battery Type
Battery Powered
▶ Physical Characteristics
Color
Ivory
Width
6 cm
Length
10 cm
Weight (Approximate)
61 Grams
Connection Type
Wireless (Bluetooth & 2.4 GHz USB Receiver)
▶ Miscellaneous
1 Unit (containing Mouse 1 No., User Manual 1 No., charging cable 1 No.)
One Year Warranty
▶ Additional Information
Manufacturer's Name & Address
Acer Incorporated, 8F, No. 88 Sec. 1, Xintai 5th road, Xizhi, New Teipei City, TW 221
Country of Origin
China
Marketed & Imported by
ACER INDIA PRIVATE LIMITED 8th Floor World Trade Center Brigade Gateway Campus Municipal Corporation No. 26 1 151 Industrial Suburb A Block Subramanya Nagar Rajajinagar II Stage Bengaluru 560055
For Pre-Sales Queries
Customer Support Department
Bengaluru-560055
Helpline No. 91-80-6234-6677
You're reviewing: Acer Flow Silent Wireless Mouse | Bluetooth & 2.4GHz Dual Mode | 3-Level 1600 DPI | 500mAh Rechargeable Battery | Up to 1 Month Usage | Type-C Charging | 10m Range | Ambidextrous Design | Ivory
