Acer Ergo Vertical Wireless Mouse | Silent 6D Buttons & Scroll Wheel | 4 DPI Setting 1200-3200 | 2.4GHz + Bluetooth Dual Mode | Rechargeable 500mAh Battery | ABS I RGB Glow | Ergonomic Design I White
ZC.A01SI.393
ZC.A01SI.393
  • Ergonomic Vertical Design – Promotes natural hand posture, reduces wrist strain, and provides long-lasting comfort during work or gaming sessions.
  • Silent & Durable Switches – Equipped with silent L/R buttons tested for 3M clicks, ensuring a quiet and reliable performance in office or home use.
  • Dual Wireless Connectivity – Switch seamlessly between 2.4GHz USB dongle and Bluetooth mode, perfect for multitasking across laptop, PC, or tablet.
  • Precision DPI Control – Adjustable DPI levels (1200/1600/2400/3200) deliver smooth cursor tracking and accurate performance for work, design, or gaming.
  • Rechargeable & Stylish RGB Glow – Built-in 500mAh BIS-certified battery supports long usage with quick recharge, while RGB lighting adds a modern touch.
  • MRP : ₹ 2 000.00 (Inclusive of all taxes) per Unit
  • Country of Origin : India
Regular Price ₹2,000.00 Special Price ₹999.00
Check Estimated Delivery Date
Details
A-Plus-White-Cover-01A-Plus-White-Cover-01
A-Plus-White-04A-Plus-White-04
A-Plus-White-02A-Plus-White-02
A-Plus-White-03A-Plus-White-03
A-Plus-White-07A-Plus-White-07
A-Plus-White-01A-Plus-White-01
▶ Technical Information
Compatibility
Compatible with PCs, laptops, MacBooks, iPads, and more for seamless use across devices.
▶ Network & Communication
Connectivity Speed
3200 Dots per Inch
▶ Battery
Number of Cells
1 Lithium Ion batteries required. (included)
Battery Chemistry
Battery Type
Battery Powered
▶ Physical Characteristics
Color
White
Width
7.8 cm
Length
11.8 cm
Weight (Approximate)
96 grams
Connector
Battery Powered
Connection Type
Dual Wireless Connectivity – 2.4GHz USB dongle + Bluetooth
▶ Miscellaneous
1 Unit (Mouse 1 No, Manual 1 No, charging cable 1 No)
1 Year Warranty
▶ Additional Information
Manufacturer's Name & Address
ACER INDIA PRIVATE LIMITED, RS No.38/2, Sedarpet Village, Villanur Commune, Poducherry - 605111.
Marketed & Imported by
For Pre-Sales Queries
Customer Support Department
Acer India Private Limited
Embassy Heights, 6th Floor, No. 13, Magrath Road, Bangalore (Karnataka), INDIA – 560025
Helpline No.: +91-80-6234-6677
You're reviewing: Acer Ergo Vertical Wireless Mouse | Silent 6D Buttons & Scroll Wheel | 4 DPI Setting 1200-3200 | 2.4GHz + Bluetooth Dual Mode | Rechargeable 500mAh Battery | ABS I RGB Glow | Ergonomic Design I White
