Acer DeskPro Monitor/Laptop Stand with 15W Wireless Charging, RGB LED (10 Modes: Breathing, Flashing, Running, Gradient), USB Hub (3USB +Type-C), Ergonomic Riser, 25kg Load, ABS Build, Desk Organizer, Black
ZC.A01SI.4VX
ZC.A01SI.4VX
  • Dynamic RGB Lighting Experience: Enhance your workspace aesthetics with 12 built-in 5050 RGB LEDs featuring 10 vibrant lighting modes including colorful breathing, flashing, gradient, and running light effects. Easily switch modes with a single press or hold for 2 seconds to turn RGB off for distraction-free productivity.
  • 15W Fast Wireless Charging: Integrated Qi-certified wireless charging pad delivers up to 15W fast charging for compatible smartphones. Supports efficient charging through cases up to 3mm thickness and includes advanced safety protections like overvoltage, overcurrent, temperature control, and FOD protection for secure everyday charging.
  • Built-in USB & Type-C Docking Hub: Transform your desk into a smart workstation with 3 USB data output ports and 1 USB Type-C data output port for connecting keyboards, mice, USB drives, smartphones, and other peripherals. Includes a durable 1.5m dual-male USB cable for stable connectivity and seamless desktop management.
  • Ergonomic Monitor & Laptop Riser: Designed to elevate monitors and laptops for improved viewing comfort and better posture, reducing neck and shoulder strain during long work or gaming sessions. Spacious 500 × 235mm platform provides stable support for monitors, laptops, consoles, and accessories.
  • Strong, Stable & Space Saving Design: Built with durable ABS material and engineered to support up to 25kg load capacity while maintaining a lightweight 1050g structure. The elevated stand design creates additional desk storage space underneath for keyboards, accessories, and office essentials, keeping your setup clean and organized.
  • MRP: ₹ 3 999.00 (inclusive of all taxes) per unit
  • Country of Origin: China
Regular Price ₹3,999.00 Special Price ₹1,999.00
Check Estimated Delivery Date
Details
HeaderHeader
Frame__01Frame__01
Frame__02Frame__02
Frame__03Frame__03
Frame__04Frame__04
Frame__05Frame__05
Frame__06Frame__06
Frame__07Frame__07
▶ Technical Information
Compatibility
Compatible with laptops, monitors, smartphones, and USB/Type-C devices.
▶ Physical Characteristics
Color
Black
8.5 cm
Width
50 cm
23.5 cm
Weight (Approximate)
1.05 Kg
Connector
3x USB data output ports, 1 x USB Type-C data output port
▶ Miscellaneous
‎1 Unit (Acer DeskPro Monitor / Laptop Stand 1 No., Manual 1 No., USB Cable 1 No.)
One Year Warranty
▶ Additional Information
Manufacturer's Name & Address
Acer I Pvt Ltd, FORCETAKE INCORPORATED, Xizhi Section, New Taipei City, 22101
Country of Origin
China
Marketed & Imported by
For Pre-Sales Queries
Customer Support Department
Acer India Private Limited
Embassy Heights, 6th Floor, No. 13, Magrath Road, Bangalore (Karnataka), INDIA – 560025
Helpline No.: +91-80-6234-6677
You're reviewing: Acer DeskPro Monitor/Laptop Stand with 15W Wireless Charging, RGB LED (10 Modes: Breathing, Flashing, Running, Gradient), USB Hub (3USB +Type-C), Ergonomic Riser, 25kg Load, ABS Build, Desk Organizer, Black
